It is currently Fri Jul 18, 2025 9:10 am
PostPosted: Tue Mar 05, 2013 11:08 am
Here are the items I will offer. I will limit this to things that are difficult to find elsewhere and are surplus to my needs. I will put things in 3 separate posts: White spruce tops, Back and side sets, and Misc.(just a few fingerboards and such).
I will be kinda busy this weekend with house guests, but will do my best to keep up here with answers to questions and such, and keep things updated.
Payment will be by PayPal to: ggoltz (at) aol (dot) com
You may pay for your items first, if you want, and then I will have a shipping address and can figure shipping for you to pay separately or you can PM me a shipping address and I will figure one total including shipping, your choice. I will not be able to start shipping before Tuesday and want to have everything out of here by the end of the week. I will use UPS shipping where possible, so an actual street address is needed. Any shipments outside the lower 48 states will be by USPS.
OK, White Spruce tops in this post. The first 4 are 10+ year air dried tops from my older wood. The last 7 are 4 year air dried and all came from one tree. For those not familiar with white spruce, it is an eastern spruce similar to red spruce, but typically has a bit lower density and is a bit softer. As with red spruce, grain spacing is a bit irregular, so it can’t really be graded comparably with other spruces. I process this wood myself and hand split the logs to minimize runout. Since logs over 24” diameter are rare, there is much more waste (bracewood) from a log than tops.
All of these have a dread outline drawn on for scale. All are well quartersawn.
10 year air dried
WS 5B-1 $60 SOLD
WS 1-01 $65 SOLD
WS 3-01 $65 (note pitch pockets which will be in soundhole)
WS 2-01 $50 (small pitch pockets at upper end)
4 year air dried
WS B1-1 $55
WS B1-2 $55
WS B1-3 $55
WS A2-1 $55 SOLD
WS B2-1 $50
WS B3-1 $55
WS B3-2 $55
Thanks for looking :D
Grant
PostPosted: Fri Mar 15, 2013 2:25 pm
Back and Side sets
I will start with a few Cambodian Beng sets. This wood is difficult to find. Similar in density to Brazilian rosewood. Very stabile, easy to bend, and excellent workability. All of this wood is 20+ years air dried. I have built with it, and am very pleased with the results. The first 2 sets are sister sets to the one Colin Symonds built with. The remainder are a variety. This wood all cost me the same, so I will price all sets the same, $88.
CB-01 $88
Backs 6 -8” wide x 21 ¾, sides 5 x 36
CB-02 $88 SOLD
Same size as above set
CB-03 $88 SOLD
Backs 8 5/8 x 21 ¾”, sides 4 7/8 x 34”, cracks far outside of pattern
CB-04 $88
Backs 8 ¾ x 21 ¾”, sides 5 x 34”
CB-05 $88
Backs 9 x 22”, sides 5 x 34”
CB-06 $88
Backs 9 x 22”, sides 5 x 33 ½”
CB-07 $88
CB-08 $88 SOLD
Backs 8 ½ x 21 ½”, sides 5 x 34”
Next a couple of high grade cocobolo rosewood sets
Coco104-A-1 $206
Backs 8 ¾ x 22”, sides 5 x 33”. This is a very colorful perfectly quartersawn set with a center sapwood blaze. The sides appear to be from another billet from the same log as the backs. Air dried since 2004
Coco2004-4 $258 SOLD
Backs 8 ¾ x 23 ½, sides 5 x 36”. Cut from a mostly air dried log that I purchased in 2004. Absolutely amazing figure and color. The sides WILL match the back in color under finish. I know because I have built with this wood. This is from my best coco and I am offering this set from my personal stash (saving some for myself)
Now, for the luthier who has everything. Snakewood in sizes wide enough to squeeze out a full sized 2-piece backed set from is almost non-existent. I will share this jumbo sized one from my private stash.
Snakewood-1 $1,500
This exceptional set has backs and sides cut from the same log. Backs are 9” wide by 23” and sides are 5 – 4 1/2 “ wide by 34”. Air dried wood, I am not sure how long, I have had it for 5 years. I have never seen a snakewood set this size anywhere, and I have looked a lot.
Just a note on bending snakewood. First of all, this wood feels more like metal or glass than wood. It is very hard and dense. I suggest thinning the back to no more than .085-.090". Do not attempt to bend the sides thicker than .080", .075 on a tight cutaway. This wood is very strong, so thinness is not a problem. I have tried bending the sides dry, but it is difficult and there is springback. Solution - soak sides in hot water for 1 hour prior to bending. Bend at 325 degrees. Bends very easily, stays flat across the grain, and no springback. I even took a dry side that I had bent as a regular side, soaked it to straighten it, and then bent it as a cutaway - worked perfectly.
Grant
PostPosted: Fri Mar 15, 2013 2:28 pm
Fingerboards
Just a few odds and ends
Oversized quartersawn ebony boards, 5/16” thick, Sizes as indicated. Note cracks obvious on lower right corners. There are also some short repairable hairline checks in aboutthe first inch of the lower end.These are straight grained and quartersawn and should finish black.
Number 1 (left) $35, Number 2 (right) $30
High figure Snakewood fingerboard $100. SOLD
This came from the same logs I cut the back and side sets from.
Medium figure Snakewood fingerboard $50. This is 3/8” thick and you should be able to squeeze out a bridge blank. Also, the offcuts make excellent nuts and saddles.
That’s about it, unless you beg for more ;)
Grant
PostPosted: Fri Mar 15, 2013 7:04 pm
sigh...thought I could resist the temptation...but no...
I must have:
Coco2004-4 $258
PostPosted: Fri Mar 15, 2013 7:22 pm
I'll take cb-03 and WS A2-1
PostPosted: Fri Mar 15, 2013 8:35 pm
First name: Patch
Last Name: Rubin
i'd like a set of cb-08 if still available.
http://www.wideskyguitars.com
https://www.instagram.com/wide_sky_guitars/
PostPosted: Fri Mar 15, 2013 8:38 pm
Got 'em. Thanks Zach
Grant
PostPosted: Fri Mar 15, 2013 8:39 pm
Thanks Patch. It's yours
Grant
PostPosted: Fri Mar 15, 2013 9:59 pm
First name: Big
Last Name: Jim
CB01 or CB02 , which ever one is left I want [:Y:]
PostPosted: Fri Mar 15, 2013 10:08 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Grant, I don't see the snake wood back and sides for sale.
Sent from my walkie talkie using Tapatalk
PostPosted: Fri Mar 15, 2013 10:30 pm
It's there, bigger'n life!
PostPosted: Fri Mar 15, 2013 10:50 pm
State: ON
I'll take the high figure SW fretboard for $100
I'll PM you to work out shipping.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Fri Mar 15, 2013 11:25 pm
Hi Grant,
I would like WS 5B-1 and WS 1-01.
PostPosted: Sat Mar 16, 2013 2:34 am
I already marked CB-2 sold to you, so CB-1 is still available for somebody else.
G
PostPosted: Sat Mar 16, 2013 6:15 am
State: ON
Josh
Don't forget to mark the snakewood fretboard as sold!
Josh
Josh House
PostPosted: Sat Mar 16, 2013 1:19 pm
Well here are a few more.
Since all of the straight grained Cambodian Beng sets are sold, I am adding 2 more. These sets are identical.
CB-09 $88 SOLD
Backs 8 ½ x 21 ½”, sides 4 7/8” x 34”
CB-10 $88 SOLD
Backs 8 ½ x 21 ½”, sides 4 7/8 x 34”
And here are a couple of Goncalo Alves sets. Goncalo alves is a dense, rosewood-like wood from Central America. It is fine grained, easy to work and bends well. These sets are from perfectly quartersawn wood that has air dried over 5 years. Another supplier has offered this wood and referred to it as being similar to mahogany. Either they have a different wood, or they made an error. This wood in no way resembles mahogany. Under a finish, this wood shows a light shimmering curl. With exposure to light, this wood darkens considerably. The lighter reddish colors become a rich deep brick red and the darker streaks become black.
This is one of my favorite woods to build from and I have completed several guitars from it.
Goncalo Alves-01 $112 SOLD
Backs 8 ¾ x 22”, sides 4 7/8 x 34”
Goncalo Alves-02 $112
Backs 8 ¾ x 22”, sides 5 x 35”
Thanks for looking,
There are still things left in the first three posts :D
Grant
PostPosted: Sat Mar 16, 2013 4:48 pm
First name: Tom
Last Name: West
State: Nova Scotia
Grant: I have quite a bit of wood and am planning on moving this summer. If not I would be all over those new additions of Beng. Very very nice sets. They won't last long.
Tom
PostPosted: Sat Mar 16, 2013 5:29 pm
Grant -
I'd like the last two sets of Beng -#9 and #10 - if still available. Shipping to 49071.
Tom
Tom Barton
PostPosted: Sun Mar 17, 2013 9:23 am
Hi Grant... I'd like to get - Goncalo Alves-01 $112
Thanks!
Bob Long
PostPosted: Sun Mar 17, 2013 11:03 am
Thanks!
Bob Long
Thanks Bob. You got it,
Grant
PostPosted: Sun Mar 17, 2013 1:30 pm
Last Name: Ensor
City: Springfield
State: Missouri
Grant,
Since this is a "swap"-a-palooza, I am interested to see if you would like to swap some tonewood. I have a nice set of zebrawood (a sister set to the one pictured here):
I am interested in CB-07. Would you be up for a swap? If you aren't interested in zebrawood, is there anything you would be willing to swap for?
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Sun Mar 17, 2013 3:14 pm
Chris Ensor wrote:
Grant,
Nice zebra. Unfortunately, I have a pile of sets and about a dozen uncut 10 foot long boards - more than I will ever be able to use :shock:
But I am not adverse to swapping, what else you got? I will forwarn you that it Will have to be something off the beaten path, because I have piles of the usual.
Grant
PostPosted: Sun Mar 17, 2013 3:54 pm
Last Name: Ensor
City: Springfield
State: Missouri
I don't have many sets to trade but I have some wenge finger boards and some bois de rose finger boards. I also have some ovangkol, walnut, and padauk head plates and rosette blanks. I also have plenty of wedge binding. Oh, and a bocote bridge blank or two. Any of that strike your interest?
PostPosted: Sun Mar 17, 2013 7:31 pm
I'll take the medium figured snakewood fingerboard Grant. Shipping to T2Y 4N7 Calgary, Canada. Thanks!
PostPosted: Sun Mar 17, 2013 8:10 pm
You got it Darrel. Thanks,
Grant
